any alternator
Old 07-03-20, 10:28 AM
any alternator
If you match the output even roughly and can fabricate a bracket that will secure it and line up the pulley..
then you can use any smaller alternator in your small car,no?? maybe not with warranty but it could be done..?
Old 07-03-20, 01:28 PM
R
Received 27 Votes on 23 Posts
In theory, yes. But you would need to use the same diameter pulley, the correct voltage regulator and find the proper belt to fit on all the pulleys . Just get the proper replacement for your application, it will be more cost effective in the end as some ideas are better left as just that, ideas.
