Tire question
Old 07-30-20, 06:03 AM
Tire question
Hello,
Just getting some insight on this as I just noticed yesterday. My PT cruiser front tire was getting a few pounds low on air so I filled it and noticed the following. The tread seems okay about 4/32". There are 3 groves between the treads across the width of the tire. In one of the grooves ( center one) you can see the cords coming through the rubber. The other tire is not like this. I have always seen this near the side wall where the tire is really worn but never in the grove when you still have a good amount of tread left. Is this bad and should I change asap. Thx
Old 07-30-20, 06:08 AM
Received 291 Votes on 259 Posts
If you have exposed cords you need to replace the tire! Sounds like an odd scenario for the cord to be exposed? how old are the tires? possible warranty/recall?
Old 07-30-20, 06:10 AM
Probably 3 years 20,000 miles
Old 07-30-20, 07:07 AM
scoob8000's Avatar
Received 2 Votes on 2 Posts
Anytime you can see the cords I would definitely change the tire asap. You could end up loosing a chunk of tread or worse have a total blow out.
Without a picture, the only thing I could picture in my mind is the casing split and is letting the cord show. Either dry rot, cut, defect, etc.
Old 07-30-20, 09:32 AM
CasualJoe's Avatar
Received 83 Votes on 73 Posts
1/8"......time to replace, those tires are worn out.
Old 07-30-20, 07:29 PM
iceman681's Avatar
Received 3 Votes on 3 Posts
get two matched tires on the front and get an alignment. something is wrong
