How to remove tape residue
Old 08-08-20, 05:53 PM
B
https://imgur.com/a/jKTqNJg
The residue are on the windshield and the part on top of it. I have already tried to use a hairdryer to heat it up to remove it, but it didn't work.
Popular Reply
08-09-20, 07:06 AM
2granddaughters's Avatar
2granddaughters
2granddaughters is offline
Received 10 Votes on 7 Posts
WD-40 works very well on tape residue
Old 08-08-20, 06:03 PM
C
Received 6 Votes on 5 Posts
Some glues can be removed with rubbing alcohol on a rag. Others can be removed with lighter fluid on a rag. Substitute gasoline for lighter fluid if you don't mind the smell. Good luck with it!
Old 08-08-20, 06:10 PM
Received 75 Votes on 70 Posts
I'd scrape what I could with a single edged razor blade, then use Goo Gone on a terry cloth rag.
Old 08-08-20, 07:17 PM
Norm201's Avatar
Received 227 Votes on 202 Posts
Try using silicon spray. That's always my go to remover. If that doesn't work then use the goo gone or similar. Acetone might work also.
Old 08-09-20, 07:06 AM
CasualJoe, Norm201 voted this post useful.
