Power steering fluid leak - 2015 Buick Enclave
Old 08-11-20, 05:10 AM
D
Received 1 Vote on 1 Post
Had car in local shop for brakes and oil change. I thought I had a small oil leak but it turns out it was power steering. The mechanic topped off fluid but didnít think it was a big leak. A few days later Iím noticing more and more fluid on driveway and wheel was very hard to turn when pulling out of a parking spot, and was making a whining noise on the curves of off ramps. Fluid level was very low, I added fluid and everything seemed better. Taking car in today to same local shop. Should I expect to replace PS pump or could it be a leaky hose? Car has 119k miles.
Old 08-11-20, 05:15 AM
Received 300 Votes on 266 Posts
It depends on what's leaking. A bad hose/fitting is the most likely culprit.
Old 08-11-20, 05:18 AM
Marq1's Avatar
Received 356 Votes on 332 Posts
Impossible to diagnose an issue sight unseen, anything is possible!
Old 08-13-20, 09:22 AM
D
Mechanic said front seal of PS pump leaking, replaced pump
Old 08-13-20, 09:35 AM
thanks for the update ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
