Headlight bulb replacement for 2015 Buick Enclave
The attached is a pic of the bulb in the car now that needs replacement. Does the 4c12 mean anything? Or the 003383 11? Seems the replacements I see online, including amazon, have all different variations of this bulb. I did find a replacement on Amazon with the numbers 9285 301 244 and is 35w. Assuming I need the entire metal housing, not just the bulb. I have seen
prices from 30-80 per bulb. Don’t wanna spend a ton but want a comparable bulb so willing to pay to get exact or close match. Just replacing the one that’s burned out not both.
Last edited by PJmax; 08-13-20 at 11:23 PM. Reason: reoriented pic and added arrow
That's a Philips D3S HID 35w 4300k bulb
The GM part number should be 13587843.
Here's the problem..... there are different colors and light intensities.
When you buy a non OEM product you don't know if it will match the remaining bulb.
Link to illustrate correct lamp
Original bulb
Original bulb
