Steering Rack & Pinion Bellow Leaking?
Hi,
I am not sure what exactly the part's name. I believe it is right steering rack and pinion bellow. There is oil on it. Not sure if this is leaking. About to do a road trip, but want to make sure if this is something I need to get fixed before travel. I have attached a few pics. The car is 2005 Toyota Camry
Thanks in advance.
Thanks in advance.
The seals on the ends of the rack are leaking into the boots. They usually just get progressively worse/ At some point it will begin leaking on the driveway, its usually not a catastrophic failure but need to keep the fluid level filled!
