Dashboard lights on. brakes plus ABS on
Old 11-20-20, 10:52 AM
B
The info is saying to check the wheel sensor. Where or what is that??
2001 Dodge Caravan sport
Brakes work fine.
Can you check wheel SFNSONS
Old 11-20-20, 03:37 PM
B
Received 93 Votes on 81 Posts
If you don't have an OBD code reader, check with your auto parts store. Most will read the error codes for free and recommend parts to fix if you are a DIYer.
Old 11-21-20, 06:20 AM
Wheel speed sensor
You can stop at any auto parts store and the will lend you a code reader. Follow the prompts and it should tell which wheel. If not, in the tests section if it has it, you can drive and monitor the 4 wheels for signal. No signal is your culprit. The sensor is the black wire that plugs into the backside of the dust shield for the brakes. They do break or fail
Old 11-21-20, 08:29 AM
ukrbyk's Avatar
Received 12 Votes on 9 Posts
Front ABS sensors are in the hub. You should be able to see wire going to them even with just wheel turned out all the way. They are, normally, easily removable.
Rear ones are tough. often, they are integral part of the rear hub.
