2016 Dodge Charger having slips
Old 02-24-21, 08:58 AM
i have a 2016 dodge charger sxt, it is heavy cranking before it turns over and when it does it doesnt want to excelerate, i have replaced all the spark plugs and the ignition coils and a camshaft postion sensor, not sure what else, maybe the o2 sensor? any input would be greatley appriated
Old 02-24-21, 09:06 AM
P
Received 867 Votes on 798 Posts
"...is heavy cranking before it turns over..."
What exactly does that mean? Is it like a weak battery or poor connection causing the starter to barely turn the engine over?
Old 02-24-21, 10:44 AM
B
Received 111 Votes on 97 Posts
Your car has on board diagnostics (OBD) that will turn on Check Engine light when any of the sensed parameters is outside the acceptable range and provide the faulty parameter code via a reader connected to the OBD connector under the dash. What was the basis for changing spark plugs, ignition coils and camshaft position sensor?
Old 02-24-21, 09:41 PM
Received 16 Votes on 11 Posts
It's still a fairly new vehicle. Is it no longer under warranty? I would look into getting a scanner to help steer you in the right direction. Throwing money at parts typically doesn't work out well.
Old 02-25-21, 06:19 AM
Received 11 Votes on 8 Posts
How many miles on the vehicle? How long have you owned it?
Did this problem happen "all at once" or has it deteriorated over time?
Old 02-25-21, 06:23 AM
ukrbyk's Avatar
Received 16 Votes on 13 Posts
You either have fuel supply issue or leaking injectors, flooding spark plugs with fuel, causing extended cranks before engine fires. Also, check air filter. If you do not have good air supply, you run rich.
Old 02-26-21, 08:43 AM
my obd reader giving me codes of , p0335 u1424 p0300, it has 69000ish miles on it
Old 02-26-21, 01:01 PM
B
Your engine has a timing issue between the camshaft and crankshaft. Difficult to troubleshoot without shop type diagnostic equipment. You can try changing the sensors but I would go to a Dodge dealership.
