Hello,
Apologize if this is not the right forum. I have a MIG welder and want to remove some dents and change the radiator support and was wondering if there is a attachment for spot welding for MIG available anywhere?
I can spend money on spot welder but i hardly use it and don't intend to use it frequently.
Any suggestions will be of great help. I will put my pics of dent which i want to pull.
Yes, there are spot welding guns/kits for mig welders. I normally just use the mig though. With some practice it's relatively easy. For thin gauge metal like body work I usually use TIG so I'm not sure how much help your mig will be for this project unless you'll be hiding the welds under body filler.
eastwood company has a stud weld kit that would fit over your mig nozzle to help you spot weld studs you could probably make something similar fairly easy that will hold the stud as you spot weld, really do not see those dents coming out very well though typically dents with creases are not going to pull out very well but you may at least be able to use less filler material.
If your thinking about welding studs to that panel that would then use a slide hammer to pull them out it's going to be extremely difficult if not impossible to accomplish.
That process works best on large panels with soft dents, small panels, like a rocker, with deep sharp bends are very stiff . Rockers when damaged to that extent are usually replaced, or filled with a gallon of bondo which I do not recomemend!
Thanks @PilotDane , @alan73 and marq101
@Pilot Dane - You are right for light metal work it will good to use TIG rather then just MIG welder.
@alan73 - You are absolutely right and i got the idea watching their youtube. But they said they are not sure when the stock will be available. Marq1
Thats what my friend said that its going to be nearly impossible and imperfect which i am fine with as there is no rockler panel i can find nearby or ebay especially left side.
Question i have is how do i remove the rockler panel in toyota camry 2003 LE 3.0L body.
Hmmm, there was something familiar!
There is typ a pinch flange under the threshold trim and under the doors which you can see in your picture. They are spot welded in place, have to drill out the spot welds.
I just noticed the 2003, not sure I'd put a lot of money into something that old!
@PJmax
Yes between covid and other things with family never worked on that part of the car. Everything else replaced slowly. Suspension to exhaust to radiator and axle.
As i find cheaper parts i am replacing so not to spend too much and keep the car going.
@Marq1
You are absolutely right. This is more emotional attachment to the car then really the value.
I am hoping not to spend lot of money at the same time make sure it looks good.
That's why i was hoping to see if somehow i can pull out the crushed section of rocker panel.
I am going to try this by weekend. Don't know if its risky.
1. remove front wheel and fender.
2. In my new attached pic - All the left the vertical small welding and already small gap. i will remove the welding
3. It will be enough gap to put something to push the metal out and pus it little down which will create more gap.
4. This will allow to straighten but not perfect and then do the welding again and then bondo.
I believe that might be cheapest and satisfying option.
Hi All,
Looking to see your thoughts on this. Have to my current 2002 PT cruiser. Looking at a 2016 Hyundia Sonata with 73K. The car fax is clean and has had regular oil changes and maint.. We did receive the Vehicle cost - RO sheet from the Hyundia dealer on what they did to the car when it arrived. The concerning thing is as follows. After searching the internet on The 2016 Sonata it appears they suffer from excessive oil usage with some adding 1-2 quarts between oil changes and their is even a couple class action lawsuits for this issue. In fact this looks to be true for many other year Sonatas, Hyundia vehicles and Kia's as well. The carfax shows oil changes but no other info. The dealer RO sheet shows that the vehicle has a history of burning oil, they removed the valve covers and checked for oil sludge and also checked the cylinder walls and that all seems ok with no sludge found. This will be a first car for my 19 year old son who will probably put 10K a year on it but the loan will be for 5 years. I am wondering what your thoughts are and if this is a vehicle that we should stay clear of as i know it will probably be opinions only. We have not bought used vehicles in many years as we always lease. Unfortunately it seems that every vehicle you search for online has some kind of issues. Thx for any info. Read More
I know the official and technical answers, but I'm asking the practical and common question.
Daughter brought her 2017 car in for an oil change. Not to the dealer or her regular shop, but to a quicklube center. They tried to convince her to change out transmission fluid and even scared her when they said it should've been done two oil changes ago! She said no and called me. Based on age and milage I said if you don't have a problem leave well enough alone. Unless the fluid is low, or the fluid looks burned, or there is an obvious leak, or the car has been stressed more than normal operating conditions. I explained that it is a closed system and not exposed to enviromnetal conditions as oil might be. Transmissions are well built and don't need regular fluid changes. I only had one vehicle that ever needeed a transmission fluid change and that was after 100,000 miles and well over 10 years old.
My question is how often do most of you change out tranny fluid on you cars?
Read More
