car A/C
Old 10-01-22, 08:07 PM
K
car A/C
what is wrong with my aircon on my car
the low pressure side reads 100psi
the high reads 120psi
that at about 1100rpm
Old 10-02-22, 02:09 AM
Received 3,615 Upvotes on 3,241 Posts
Welcome to the forums.
thread moved to the auto forums.
Are you sure the compressor is operating.
Make sure when the clutch engages that the center part of the compressor is turning.
You should see an immediate pressure change when compressor engages.... if you don't... it's shot.
Old 10-02-22, 06:43 AM
ukrbyk's Avatar
Received 51 Upvotes on 42 Posts
Or, clutch is shot. Bad clutch does not mean bad comp. Or, fuses/relays are. Or, bad connection to clutch.
Before man jumps on replacing costly parts.....
Old 10-02-22, 10:03 AM
If the clutch was shot the compressor wouldn't be turning.
