2012 maxima vvt solenoid
Old 11-09-22, 01:48 PM
8
Hello !
Anyone happen to know the bolt size to hold the vvt solenoid in place ? I dropped mine into the abyss and it has vanished !
thanks !
Old 11-10-22, 06:37 AM
ukrbyk's Avatar
Received 50 Upvotes on 41 Posts
Which socket did you use to undo it? 10mm? 12MM? That tells you bolt size. Then you have 3 different pitches in that size.
Old 11-10-22, 06:50 AM
B
Received 258 Upvotes on 230 Posts
Check with a Maxima dealer parts department.
Old 11-10-22, 10:39 AM
Received 3,598 Upvotes on 3,227 Posts
The V V T solenoid uses three bolts. Take one with you to match another.
Old 11-10-22, 07:10 PM
8
part # 0810A0-6161A
dealer didn't know actual bolt size and had none in stock
this year has 1 bolt only
​​​10mm stub wrench to remove
thanks for the feedback !
Old 11-11-22, 06:35 AM
ukrbyk's Avatar
What size bolt uses a 10 mm socket?
If you mean what size bolt has a 10 mm head, it is a 6 mm bolt.
https://monsterbolts.com/collections...bolts/size_-m6
And you want automotive grade bolt.
Old 11-11-22, 06:58 AM
B
If manufacturer's documentation for dealers only deals with numbers for parts, then its about time there is a federal law that requires car manufacturers to provide documentation in new autos with their number for every part in the auto. Then, after market suppliers can provide correct part by cross reference.
