2014 Dodge Journey A/C problems
Old 05-20-24, 01:04 PM
N
I tried to use my ac today my controls are all the way down for cold I hit the ac button and the air only goes towards the floor now i just had a heater hose and 2 thermostats put on a couple weeks ago does anyone know what would be going on
Old 05-20-24, 01:46 PM
the_tow_guy's Avatar
Received 262 Upvotes on 213 Posts
Blend door issue. Mostly those are either vacuum or electric motor driven unless the door itself has failed (cracked.broken, etc). On a lot of cars that is a flaming pain because the dash may have to come out for access. Best to have an AC specialty shop have a look.
bartoneml voted this post useful.
Old 05-20-24, 01:49 PM
Might also check for youtubes on the subject.
Old 05-20-24, 06:15 PM
Received 4,099 Upvotes on 3,682 Posts
I see many passengers side problems. That would indicate an electronic climate controlled system.
You said slide control which means basic system with no driver side/passenger split.
The videos below cover the blend doors. The videos illustrate dual blend doors/ actuators.
They may not be your exact system but illustrate how the blend doors work and where they are.
Journey blend door video
Old 05-21-24, 04:46 AM
B
Received 314 Upvotes on 277 Posts
Heater hose and thermostats have little affect on A/C mode of the car's HVAC system. Your problem is in one or more of the electric operated doors in the HVAC plenum.
