96 lumina van back 3 plugs how do i get to them?
HELP!
96 Lumina van with 3.4 v-6
changed the front 3 plugs and wires how do i get tho the back 3???
maybe some help
I have a 1993 Lumina sedan. I don't know if your's is the same but to get to mine you rotate the engine forward. There are brackets on the top toward the radiator, I detach them and then have someone 'rock' the car forward/back until then engine rotates forward then put a bolt thru a slot up front to hold the engine forward. Even when doing this the plugs are hard to get at. Check a service manual to see if your engine rotates.
