fule system on 91" plymouth grand voyager
Old 01-09-02, 07:21 AM
Guest
Angry fule system on 91" plymouth grand voyager
The darn thing just won't start.
no pressure in injectors
Is the fule pump out?
or is it a computer glitch or ground maybee?
any help greatly app. thanks
levi
Old 01-09-02, 07:31 AM
Joe_F
Could be a number of things.
How do you know there is no "pressure" to the injectors? You need to check the fuel pressure with a reliable gauge to know that .
Must check fuel pressure. Must check to see if you have spark. Have a blue, fat consistent spark all the time. If not, an ignition problem.
Check my post "The Basics" for more ideas. Post what you find as a result of checking that.
The engine size of this vehicle is also helpful .
Old 01-09-02, 07:36 AM
Guest
thanks
thanks joe i will give it a better post in the future
Old 01-10-02, 01:48 PM
T
91 Caravan
We had a problem with our 90 Caravan once similar to that and it was a pickup which is mounted under the distributor. If it don't see a spark it will cause the computer to stop the fuel pump. I found this out AFTER I changed the fuel pump. Its worth a check...... Good Luck!
