1997 Ford Taurus Flasher
Old 01-10-02, 04:58 AM
Guest
Where is the t/s flasher located? It is not in the fuse box. I feel like I've taken residence under the dash of my car. Please help!
Old 01-10-02, 05:09 AM
If it's still working, I would say turn the hazards lights on, and listen for it. If not, then the easiest way would be to run to the local library or parts store, and look in one of the Chilton or Haynes books for your car. They will tell you where the flasher is located. In most cars it's the the left side, but I've seen it in the right side also.
Old 01-10-02, 05:53 AM
Joe_F
Usually to the right of the steering wheel, in the fuse box or under the dash buried. Most times the owner's manual tells you where it is, so check there too.
A quick call to the Ford dealer or any parts store that has a Wagner lighting catalog should net you the location. Some cars use a relay, not a flasher.
Old 01-10-02, 03:16 PM
It uses an electronic flasher and it should be just to the left of the steering column under the dash.It lookes like a square relay and is usually attched to the dash with one screw.
