blower motor
Old 01-12-02, 07:28 AM
Guest
Question blower motor
have 97 sts can someone tell me where the blower motor is located and if you accsess from inside or the outside of the car?
thanks for the help
Old 01-12-02, 08:24 AM
knuckles
The blower motor is under the hood. Here's the R&R procedure:
Remove or Disconnect
Negative battery cable.
Cowl cross-tower brace.
Disconnect electrical connectors from ignition control module.
Position cross car harness out of way.
#5, and #7 plug wires. Position spark plug harness out of way
Solenoid purge valve.
Inertial plate from blower motor.
Important
Re-install two screws with washers to prevent the motor and housing from separating during removal and installation.
Connector from blower motor.
Blower motor screws.
Rotate blower motor so that the flat side is down. Refer to Figure 43.
Blower motor.
Install or Connect
NOTICE: Failure to maintain a 25 mm clearance between spark plug wires and HVAC blower motor may result in improper operation or failure of blower motor.
Remove the inertial plate for the new blower motor
Important
Re-install two screws with washers to prevent the motor and housing from separating during removal and installation. Leave blower motor in box to reduce the amount of handling of the blower motor.
Blower motor.
Inertial plate.
Tighten
Torque screws to 1 N.m (7 lb. in.) .
#5, and #7 plug wires for spark plugs. Reposition spark plug harness.
Reposition cross car harness.
Are you sure the blower motor is bad?
