rough idling,sometimes,1993 Aerostar
Deltadudey2k's Avatar
01-14-02, 12:15 PM   #1
Deltadudey2k
Installed doublePlatinum plugs,new fuel & airfilters. did all the cleaning advised to do.Changed Transmission fluid.It runs great and reduced fuel consumption by 20% Now after idling for a few minutes it" surges" of "lunges" not every time but more than 50%. What have I done? What can I do?
You have helped before know you can again. Thanks, Deltadude
trinitro's Avatar
01-14-02, 01:17 PM   #2
It sounds like a vacuum leak, or some sort of intermitent connection...but I'm not a "real" mechanic...
Joe_F's Avatar
01-14-02, 02:59 PM   #3
Joe_F
Surging at idle ("hunting") on most Fords is a bad idle air control valve or gunk in the throttle body.
Look at my post "The Basics" and run the code check as outlined at www.batauto.com
BTW: Regular Motorcraft plugs listed for this would have been fine. No need to shell out the greenbacks on those expensive plugs
