electrical auto repair
's Avatar
01-14-02, 03:20 PM   #1
i have a 1984 190e mercedes with a 4cyl. motor. car starts, but no spark. it has new plugs, fuses, starter, motor relay. what could be the problem?
Joe_F's Avatar
01-14-02, 03:52 PM   #2
Joe_F
Bad ECU, bad ignition module, coil, etc.
Do you get spark in and and out of the coil?
Gix's Avatar
01-14-02, 06:16 PM   #3
Gix
if it has a dist cap (easily accesable) you may want to pull it off and check to see thats its turning while you crank the engine over ?
's Avatar
01-14-02, 08:25 PM   #4
a new distributor has been installed, thinking it was the problem. the coil checks out okay on the meter. by the way, it is a manual trans on the '84 mercedes 190e. the injector is working too. car does have a problem starting even with a new starter.
Joe_F's Avatar
01-15-02, 09:06 AM   #5
Joe_F
Has the computer and all grounds to it checked for damage?
