low heat in passenger compartment
Old 01-16-02, 08:49 AM
MICMUNDAY
1985 volkswagen Jetta. Have replace radiator,
water pump and thermostat, flushed out heater
core. Also checked blend door for proper operation.
Heat comes and goes,
Old 01-16-02, 10:22 AM
Joe_F
Are the heater core hoses always hot when the heat's on and the vehicle is warmed up? If not, the problem is still in the cooling system. Likely a clogged heater core.
If they are hot, the problem is still inside the car at the blend door.
