Dodge truck high idle
OldFart's Avatar
01-16-02, 11:17 AM   #1
OldFart
I own a 1990 W250 Dodge 4 wheel drive p/up w/360 V8 engine.
All of a sudden my idle speed and even when not in idling increased about 3 times. It doesn't appear to be the linkage as the return spring is pulling the cable all the way back to the stop, also I tried manually manipulating the cable and it makes no diff as far as the overspeed. Any helps??? Thanks Ray
Joe_F's Avatar
01-16-02, 01:32 PM   #2
Joe_F
Bad idle stop solenoid/control motor or other throttle restriction, or a possible vacuum leak.
