Won't Start after front suspension repair
koomaster's Avatar
01-16-02, 01:22 PM   #1
koomaster
I have 97 Honda Accord that won't start.
I damaged front wheel recently by hitting the curve a bit hard on the passanger side . The front suspension was repaired and steering rack replaced. The day I got my car back from the shop, it ran fine w/o any problem starting up.
Next morning when I try to start the car, nothing happens. The engine doesn't crank. I got it to start by pushing my car few feet in nuetral. This was Saturday. Next morning, I was barely able to start the engine and drove about an hour. I parked the car for 2 hours and when I try to start it up, absolutely nothing happened. No cranking. I had to jump start it. I checked the battery visually, and saw green light throught hole on the battery.
Any thoughts on this. I never had start up problem with my car until this repair.
Koo
Joe_F's Avatar
01-16-02, 01:30 PM   #2
Joe_F
If the battery checks out, check for a bad starter or loose connections to it.
If you jump start it and it works, likely a bad battery or an alternator that's discharging it.
greez_munky's Avatar
01-17-02, 10:35 AM   #3
greez_munky
You might use an ammmeter to see if your are getting power to the starter. Just to make sure there is power getting to it. Just a thought.
