Ford Escort Central Locking Problem
Old 01-17-02, 09:03 AM
The Soulgirl
HELP....
I have a Ford Escort... when ever I unlock the driver side door the central locking goes bananas but not when I use the passenger side. Is there a way I can fix this or do I have to buy a new locking device?
Old 01-17-02, 09:26 AM
knuckles
We need to know the model year of your Escort.
Old 01-17-02, 09:35 AM
The Soulgirl
Its 1981
Old 01-17-02, 10:02 AM
Joe_F
You must have something aftermarket controlling the locks. 1981 didn't have central locking. Aftermarket alarm or anything in there?
Do you mean the power locks don't work? Could be a stuck actuator.
Old 01-17-02, 10:11 AM
The Soulgirl
Its not an after market addition. Its a celebratory model called Eclipse... just before they bought out the new body shape.
It has central locking, sunroof, colour coded bumbers mirros and spoilers
BTW... I should have also said its an English model.. does that make a difference
Old 01-17-02, 10:14 AM
Joe_F
Yes,
The 1981 Escort sold here is a different vehicle that the 81 sold in England.
The European version was better, albeit still a Ford .
We don't have central locking in 1981 Escorts made and sold here.
You would need to get a diagram of the workings of the system from the shop manual. Probably a bad controller or relay that is triggering it to go beserk .
Old 01-17-02, 10:22 AM
The Soulgirl
Thanks for all your help anyway
Garage it is then...
I will do anything to avoid paying them... they are so overly expensive
Old 01-17-02, 10:37 AM
Joe_F
Well, find out what the system looks like diagramwise and go from there. Might be something strange that is going.
Also might be worth disconnecting and leaving like that if the parts needed are expensive to obtain. Or get them used.
Might want to try to find a repair manual for your car at the local library and browse through it. That's a start.
