Previa Repairs
's Avatar
01-19-02, 06:29 AM   #1
Previa Repairs
CAN SOMEONE GIVE ME THE STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE A STARTER ON A 91 TOYOTA PREVIA. THANKS
knuckles's Avatar
01-19-02, 11:12 AM   #2
knuckles
Disconnect negative battery cable at least 1/2 hour before you begin starter removal.
On 4WD models, remove front propeller shaft.
On models equipped with manual transaxle, disconnect clutch slave cylinder and position aside. Do not disconnect clutch line.
On all models, remove battery cable to starter attaching nut.
Remove starter electrical connector.
On 2WD models, remove starter attaching nuts and bolt, then remove.
On 4WD models, remove center support bracket and starter attaching nuts and bolts, then remove.
On all models, reverse to install. Torque A starter bolts as shown in Fig. 1, to 41 ft. lbs. and B starter bolts to 30 ft. lbs. On 4WD models, torque center support bracket to stiffener plate to 43 ft. lbs. and bracket to starter to 12 ft. lbs.
's Avatar
01-22-02, 04:56 PM   #3
Previa repair of starter
Thank you very much for the info. I do appreciate your time. Thanks, Peter Sansone
