Transmission On 95 Chev Lumina Car
Old 01-20-02, 02:15 PM
MICMUNDAY
Unhappy Transmission On 95 Chev Lumina Car
I was told that low roller is out on transmission. When you come to a stop or slow down, transmission shifts out of gear momentarily until you accelerate, then it shifts very hard into first.
Question: Does this transmission have some kind of sensor that would be causing this. I removed the plenum to put new o ring in distributor shaft opening. Immediately after doing this, I would get an odd sounding backfire, I was told that this was the sound when the low roller is going out. Could I have disconnected something that would have caused this.
Old 01-21-02, 05:26 AM
Joe_F
Mileage on the vehicle?
It does sound like internal failure.
Check www.alldata.com for known bulletins on this problem.
Last time the fluid and filter were changed?
Trackbacks are On
Pingbacks are On
Refbacks are On
