1986 Pontiac 6000STE
Old 01-21-02, 06:45 PM
Guest
My 1986 Pontiac 6000 STE, 2.8 L V6 fuel injected VIN W, gives a computer code indicating a MAP sensor error. I purchased a sensor at a local parts store but cannot find the sensor on the vehicle. Do you know where the MAP sensor is located on this car?
Old 01-21-02, 08:23 PM
Joe_F
Your emission diagram should show it under the hood there. I believe if it is so equipped, it's in the right rear of the plenum area.
I do believe most if not many of these 2.8 vin W's have mass air flow sensors and don't use a MAP.
Your GM dealer should be able to furnish the location from the parts computer in a jiffy if you give them a quick call.
