1992 Cavalier turn signal
Old 01-21-02, 11:21 PM
Question 1992 Cavalier turn signal
I have a 1992 Chevy Cavalier and I am having a problem with the turnsignals. I have replaced the flasher fuse and the turn signal fuse is good. the problem is that the turn signals are not working on the dash indicators or the turn signals themselves. The hazard signals work. I am at a lose as to why the turn signals are not working. please help me.... Thanks
Old 01-21-02, 11:27 PM
thekeymaker
have you checked the fuses and on some vehicles there might be two flashers Don,
Old 01-22-02, 05:00 AM
Joe_F
If the bulbs check out, and the flashers for the turn signal check out (make sure you checked the right one, there are usually two), then you likely have a bad turn signal switch in the column.
Call up your GM dealer's parts dept. and get the location of the turn signal relay/flasher. Change it, it's cheap.
If that doesn't solve your problem, go further.
