'95 S-10 Spark Plugs
Old 01-22-02, 05:34 PM
G
Guest
My 1995 Chevy S-10 has a problem with one of the spark plugs. It is a 4-cylinder and the second spark plug has recently started coming out. It has only done it a couple of times. It will start getting a little knocking that slowly gets worse and then the spark plug will come completely out of the engine. The oil level etc. at fine. Thanks for your help.
Old 01-23-02, 06:04 AM
Received 1 Vote on 1 Post
Striped Threads
Sounds like striped threads. In my '91 Geo Metro 3 cyl I had the same problem with #1. As a cheap fix I used plumbers thread dope [not the tape]. Just make sure you don't over coat the plug threads or get any in the block. This got me through 2 additional years and I sold it last weekend with no more plug popping.
This is a quick poor man's fix and I can't say whether it will cause any mechanical damage.
Hope this helps.
Good Luck,
Doug
Old 01-23-02, 09:52 AM
Joe_F
Go to your local parts store and get the proper size tap for the plug hole and retap the thread. Then you can reinstall the spark plug.
A shop can handle this as well for you.
