Fan Shroud Scrape On Chevy S10
's Avatar
01-25-02, 10:42 AM   #1
I HAVE A FAN SHROUD SCRAPING ON THE TOP SIDE ON MY 1994 CHEVY S10, 4.3L, 2W DRIVE, AUTO TRANS.
I SEE NO WAY TO EITHER DROP THE FAN DOWN OR RAISE THE
SHROUD UP, AS BOTH OF THEM ARE FORM FIT MOUNTED.
PLEASE HELP. THANKS
Joe_F's Avatar
01-25-02, 10:53 AM   #2
Joe_F
The fan and clutch should come out and then the shroud will come out.
You might have bad motor mounts which are causing the engine to shift and hit the shroud.
xiii13's Avatar
01-25-02, 11:06 AM   #3
xiii13
Joe's right, check for bad motor mounts. But I've also seen where the shroud on top of the fan "flattens out" with age. People leaning on it, etc to look into the engine compartment.
Just another angle to look at.
's Avatar
01-25-02, 11:30 AM   #4
THANKS JOE & XIII13 BOTH. I'LL LOOK INTO POSSIBLE MOTOR MOUNTS.
sportster pete's Avatar
02-01-02, 06:27 AM   #5
sportster pete
fan rub
check the core support mounts or the radiator mounts. some times the rubber rings fall out or get misaligned
