firing order
chilango69's Avatar
01-25-02, 05:54 PM   #1
chilango69
firing order
Hello. hey some one can help with the firing order on a westfalia wagon,82 I'was changing the cables and I'lost the oreder so if some one can help please........
the_tow_guy's Avatar
FL
01-26-02, 08:15 AM   #2
Might want to pick up a repair manual or check the library, because you will also need to know which one is the #1 unless you already know that.
Joe_F's Avatar
01-26-02, 04:13 PM   #3
Joe_F
That pup tent is a Vanagon as I recall
The firing order is usually on the engine, in the owner's manual and such.
Many caps are also marked accordingly with the firing order as well.
TowGuy also has the right idea. A library should have a manual you can borrow.
knuckles's Avatar
01-26-02, 08:31 PM   #4
knuckles
Refer to your original posting for a diagram. Click here to view it.
Please keep all replies & follow-ups in the original thread.
Thank you.
