car repair
Old 01-25-02, 06:22 PM
G
Guest
car repair
no heat after replacing t/stat + heater core car gets up to temp coolant good inside dampers seem to work
Old 01-25-02, 06:39 PM
Trapped Air
check the system as it may have trapped air. Their could be a bleeder on the thermostat housing or you may need to loosen a hose or cap. A manual for your car should have specifics.
Old 01-25-02, 08:12 PM
K
knuckles
Agree w/ Stephen S, but we might be able to provide more info if you posted the year/make/model & engine size.
Old 01-26-02, 08:11 AM
the_tow_guy's Avatar
Received 48 Votes on 38 Posts
And some models can be a real b**** to bleed that air out.
Old 01-26-02, 04:15 PM
Joe_F
I agree with all here.
Also are both heater hoses getting hot to the touch?
If not, the problem is still in the engine side. Likely a defective (even though it's new) t/stat.
If they are both hot, the blend door is the issue.
