carb help
carb help
Here I am sitting on a beautiful beach in Melaque, Mexico and I have a problem with what I think is the carb. 85 Dodge van, 318 and I believe a carter bbd 2 barrel carb. Every 4 or 5 days the car cranks and it won´t start. When taking off the doghouse cover and looking into the carb I see very little gas getting to the carb, if I hit the accelerator 5 times it squirts gas into the carb once. The choke plate seems to be working properly and if I dump gas into the carb it will start and it will start hot all the time. I have a new fuel pump and a new gas filter. The carb has what looks like a little check valve in the inlet pipe. Thanks for the help as always.
Those carburetors are junk, so I wouldn't put it past it needing a rebuilt at this age.
Change your fuel filter as a precaution. Also do a volume check on the fuel pump. Take the line off the carburetor and put it into a glass jar. Crank the truck. You should have a steady constant and pretty good stream.
If you don't, likely a poorly made fuel pump, even though it's new.
remove the fuel line where it enters the carb, remove the larger hex fitting it was screwed into, inside is a bronze "sediment filter"....this will probably look and feel brand new; it's not, toss it in the ocean, hook fuel line back up without it, and you're off to Baja.....at first opportunity install a good in-line filter, available at all parts stores for low bucks, in the line somewhere near where it enters the carb, no more worries, guaranteed......this has cured many a friends vehicle, as well as my own.....de nada
Sounds to me like the accelerator pump in the carb is shot. If it were a filter or pump problem, wouldn't that cause a poor running problem as well? The check-ball for the accellerator pump may be sticking too.
ok, there seems like the van doesn,t have enough power but the rear end is a 293 so I really don{t know how to judge. I will change out the fuel pump as soon as I hit Texas or can get a decent replacement. Mooser, is the check valve what you{re suggesting to throw in the ocean? Just want to make sure before I lose something I won't be able to retrieve. Cheese, when I step on the gas the response is kind of nothing, even when I try to rev it doesn't help much. Thanks to all who are helping me out, it's much appreciated.
