1986 Ford Taurus fuel problem
Old 01-26-02, 03:40 PM
danielmccoy
1986 Ford Taurus, 153K miles, 6 cylinder, 3.0 liter, electric fuel pump located in tank. Haynes manual says fuel pressure should be 39 psi.
When I did a fuel pressure check ( key on/engine off) the guage initially reads 40 psi and then declines to about 8 psi within a minute. The fuel pump is very noisy and it is getting harder to start. I think I've got a pump going bad. What do you think? Should fuel pressure hold steady and not decline?
How difficult is it to replace this pump and how do you do it?
Old 01-26-02, 03:53 PM
Joe_F
Check the fuel pressure regulator. See if the vacuum line going to it has fuel in it. If it does, the regulator is bad.
If you have a Mityvac pump, try seating the diaphragm with the pump and see if it holds vacuum or not.
Sounds like a bad fuel pump though.
Old 01-26-02, 04:39 PM
danielmccoy
Pulled the vacuum line going into the top of the fuel pressure regulator and there was no fuel in vacuum line. I assume that means regulator is good?
Old 01-26-02, 05:01 PM
It sounds like your on the right track a bad pump.As far as changing it out you'll have to remove the tank or at least lower it down.It's not that difficult,basically a couple of hoses to remove and the two tank straps.
Old 01-27-02, 06:40 AM
Joe_F
I recall the original Taurus models like this having fuel pump problems.
I remember that Ford had a fuel foaming issue on one style pump and swapped to another style as a result.
I want to say the originals were Walbros on these years, and maybe a Nippondenso or two, and the new hanger/pump assembly is a revised Nippondenso.
Fordtech will refresh my memory I'm sure .
Trackbacks are On
Pingbacks are On
Refbacks are On
