01-27-02, 02:13 PM
I would like to know if there is any special technique needed in order to change master cylinder on a car with abs brakes.I have been told that you need a computer to install master cylinder on a car with abs brakes.If you can give me any information on this 95 grandam I would appreciate it very much .Thank you.
01-27-02, 05:03 PM
Joe_F
Each car differs, but usually you are ok because you are only messing with the hydraulic side, not the ABS side.
However, I suggest at minimum you pick up a Haynes or Chilton book from your library or parts store, and better yet, subscribe to www.alldata.com for the factory style information. It costs 25 bucks a year and is well worth it. You can print all the procedures right from your PC.
