Rear wiper arm
Old 01-28-02, 08:23 AM
G
Guest
Rear wiper arm
How do you remove the rear windshield wiper arm from a 1993
Mercury Tracer Station Wagon. (Not the blade; Not the motor.)
Thanks Tom Sweda
Old 01-28-02, 09:04 AM
Joe_F
See if there is a locking tab that slides. Slide it out and the arm will pull off.
If not, there is a 10mm or so nut holding it under the hinged end cover.
Old 01-28-02, 10:12 AM
G
Guest
Thanks Joe.
There's no "tab",and I can't get at a nut as the parts below the pivot point are covered by a hard black plastic cover that I also can't figure out how to remove. Any other suggestions ?
Old 01-28-02, 10:14 AM
Joe_F
Hit your Ford dealer's parts department (or just call and ask). They should be able to tell you in a jiffy.
