88 prk. ave. buick
rogerramjet442's Avatar
01-29-02, 06:00 PM   #1
88 prk. ave. buick
3.8 eng. misses and hesitates sometimes when u give it the gas. have replaced plugs,wires, fuel filter, coil pac, etc. sometimes it runs ok, then will start jumping, if u give it the floor it may smooth out for a while. have to run in D or keep the RPMs up most of the time.??????
jeff67's Avatar
NC
01-29-02, 06:51 PM   #2
I had what seems to be the same problem with a mazda 626. Does it run rough when climbing a long hill? I had replaced lots of parts and eventually thought it might be a clogged catatytic converter. The worst thing about it was that it idled fine so I couldnt just open the hood and troubleshoot it in park. Then a teenager smashed me from behind and the car was totaled......one of the happiest days of my life
Possibly you might have a clogged exaust system or bad egr valve or something related to it. Do you ever get a bad smell when its running rough?
I wish you lots of luck. When you get it fixed, please post what the problem was.
Joe_F's Avatar
01-29-02, 08:15 PM   #3
Joe_F
Lol.
Roger Smith was the President of GM at one time, you do know that, right? .
Lol.
That being said, a bad mass air flow sensor will do this. While the engine is running, rap on it with the end of a screwdriver handle. If the car misses or wants to stall, the sensor is bad. Replace it.
Common problem on these.
