z-71 problem
's Avatar
01-31-02, 04:29 PM   #1
z-71 problem
driving truck for about 2 minutes and noticed steering became very difficult. red battery light on dash came on then temp gauge went high and check gauges light popped on. stopped truck and allowed truck to set for 10 minutes started again and problems still the same stopped truck again. any ideas? should i try and drive it for repair or have it towed in?
mooser1's Avatar
01-31-02, 04:50 PM   #2
mooser1
first place to look would be at the serpentine belt driving all your accessories......I think you'll find yours is missing......
cheese's Avatar
GA
01-31-02, 05:28 PM   #3
I agree. Your belt came off, and for a reason. They don't just come off unless they're in terrible shape and break. Check the tensioner...it may be broken or gone. If it's ok, check your pulleys for breaks, looseness, bends, etc... Let us know how it goes!
's Avatar
01-31-02, 06:03 PM   #4
you all were right! had the belt replaced about 1 week ago. guess it was not done right. Could this have caused any bad damage. I only drove a mile or 2 after the problems started but the temp did get to around 240. thanks for your help
mooser1's Avatar
01-31-02, 06:15 PM   #5
mooser1
if the temp only got to 240 you shouldn't have done any damage....check your power steering fluid level, check your amp gauge to make sure it's charging, turn on A/C to make sure it's functioning, you should be good to go......
Joe_F's Avatar
01-31-02, 07:11 PM   #6
Joe_F
Nah, probably didn't do any damage. That's a good old iron V8 in there. The best there is
These guys all have it right. I agree with what they've stated.
