Crud around the valve cover
Old 02-01-02, 09:37 PM
the toyota service advisor said, I need to have the heads (repaired?). Joe, what does the job consist?
By the way, on my previous post (coolant leak - Toyota Corolla) I had the water pump replaced since the leak was getting bad and I didn't want to risk getting stuck in the CA freeway. I also had the timing belt and drive belts replaced to save on labor charges.
Old 02-02-02, 03:55 PM
Joe_F
The year, model and make of the vehicle is???????? Engine size???
Remember that I answer 100's of posts here and don't remember everyone's car, trouble or repair .
Likely a bad valve cover gasket causing the oil leak. Ask the dealer what the part being replaced is called.
