1983 Ford Bronco
Old 02-03-02, 08:52 AM
1983 Ford Bronco
I need information on Dura Spark 111 System, the vehicle died and has sat for three years. I have replaced all electrical components, timing chain, distributor, wiring harness has been redone, I have spark power going into the cap but none coming out.
Old 02-03-02, 09:05 AM
Joe_F
Check my post "The Basics" as noted below.
Get a repair manual for your vehicle and it will guide you through the repair. Possible bad distributor cap or rotor or stator/pickup inside.
Old 02-03-02, 02:39 PM
Duraspark111 system once you have spark through the coil to the center of the cap is just like any other system.Spark travels through the cap,to the rotor button to the caps pegs to the wires.
Your problem should be one of the following.cap,rotor button,or wires.
If all these listed are new you'd better inspect them.For instance i've seen new caps with no center button to contact the rotor button.
