Buick turn signals
Old 02-03-02, 05:10 PM
Guest
Unhappy Buick turn signals
The blinker lights stay on solid, front and back on the right turn signals. Bulbs and fuse are ok. Does anyone know what to do next? Nothing in the manual for this . Buick LeSabre, 1986.
Old 02-03-02, 07:04 PM
Joe_F
Try the hazard warning lights. Do they work OK?
If they do, bad turn signal flasher. In the middle of the dash, to the right of the column or in the fusebox.
Any GM dealer or parts store can point you to the location. The part is about 4 bucks and takes a minute to change when you find it.
Old 02-03-02, 07:54 PM
tstokka
blinker
ran into this problem before. turned out to be a short in the wire harness going to the bulb. mine was on a el camino and the wires were exposed to the elements under the bumper. hope this gives you an idea where to look.
