Speedometer goes out
Old 02-04-02, 03:11 PM
jj78629
I have a 1989 chevy pickup, 1/2 ton, automatic, with a 350 engine. When I'm driving the speedometer and odometer, and cruise, goes out completely. I can slap the top of the dash with my hand and it will come back on. It started doing it once a day, now every 10 miles or so. Have taken console{gauges} in dash apart and screwed it in tight, but still have problem. Help!!!
Old 02-04-02, 03:25 PM
Joe_F
Problem in the cluster or ground.
The cluster can be tested by most parts stores or Delco test centers, so find a parts store that deals with one and they can check it for you.
Old 02-04-02, 05:00 PM
jj78629
What is the cluster, and what ground are you referring too?
Old 02-04-02, 05:51 PM
Joe_F
Ya, that's why the service manual or wiring diagram is needed . It shows you what grounds go to where.
The cluster is the unit that houses all the gauges and speedometer.
