needto put new struts on
Old 02-05-02, 03:47 AM
Guest
Question needto put new struts on
im installing struts on a 91 geo storm, whats the best way to do it.
Old 02-05-02, 04:32 AM
Joe_F
Since you're in Germany, subscribe to www.alldata.com for 25 bucks years and get access to all the factory diagrams and procedures.
You can print it out and have it at the jobsite when you do it. Rent a spring compressor as well.
Old 02-06-02, 03:03 PM
redneck
Not a hard job. You will need a ball joint seperator and a coil spring compressor. Also, while it is apart replace the strut mounts at the tops of the struts the bearings in them will go bad--then you will have to take it all apart again to replace them at a later date! I just did my '91 beretta--cost less than $200 in parts. Oh ya, you will need a front end alignment when your done.
