'92 Plymouth Voyager stalling
kady80's Avatar
02-05-02, 06:52 AM   #1
kady80
Hi,
I have a '92 Plymouth Voyager that I bought used. It has been stalling out on me. Sometimes it stalls just after starting, sometimes while running and sometimes just when you're pulling into a parking place. We have replaced the started recently and had a re and re done on the transmission. What now???
Thanks in advance,
Kady.
Joe_F's Avatar
02-05-02, 09:15 AM   #2
Joe_F
Many things:
1) When was the last time it has seen a tuneup and servicing? Start there.
2) See my signature file for a link on how to pull your trouble codes from the computer. Let us know what you find.
3) Have the fuel pressure checked with a reliable gauge.
Many things to check, but start here.
billham's Avatar
08-27-03, 04:55 PM   #3
billham
Did you find out what the problem was as I am having same problem with my Plymouth
mike from nj's Avatar
08-27-03, 08:41 PM   #4
mike from nj
this post is almost two years old
it would help to know what engine you all have, it would narrow the possibilities down significantly.
Jason R's Avatar
08-28-03, 12:51 PM   #5
2 years old! lol!!!
Lemme guess.... it's a 3.0, right?
Clean the idle air control air passegway and it'll stay running for you. VERY common for the 3.0.
billham's Avatar
08-29-03, 06:09 AM   #6
billham
Thanks Jason R I will try that and will let you know how it turns out. Bye for now
billham's Avatar
08-29-03, 08:53 AM   #7
billham
I read through the applicable section of my haynes manual and I cannot find where the idle air control bypass is. Can you help me on locating.
billham's Avatar
08-29-03, 08:55 AM   #8
billham
I read through the applicable section of my haynes manual and I cannot find where the idle air control air passageway is. Can you help me on locating.
Joe_F's Avatar
08-29-03, 08:59 AM   #9
Joe_F
Have a look in autolibrary.org below.
08-29-03, 03:51 PM   #10
mike from nj
it would still help to know what engine you have.
it would narrow the possibilities of your problem down significantly.
spooge031's Avatar
08-30-03, 07:10 PM   #11
spooge031
try cleaning the throttle body,this is the FIRST thing I look at when I get a stall out/ stumble or hard to start Chrysler if it is all gummed up the IAC motor can only adjust so far before it is at it's limit
