oops (1976) camaro, wrong year typeo
Old 02-06-02, 12:27 AM
Guest
oops (1976) camaro, wrong year - re: water pump
Sorry, it's a 1986 Z28 Camaro not a '76 - typeo.
I am sending this reply to an earlier question referring to a water pump rotation new style (serpentine belt) tune port engine which I was told that the water pump has counter-clockwise rotation. I have another 350 cu. in. which may be a year older and it has the standard v-belt on the water pump which I was told had the standard clockwise rotation. What I'd like to know is - can I put the counter-clockwise serpentine system and water pump on the older motor that required the clockwise rotation? I do know that it will bolt on there, but will the reverse flow cause problems?
Old 02-06-02, 01:18 AM
knuckles
Yes, you can install the complete serpentine system and reverse-rotation water pump on earlier engines. The pump is not a reverse-flow pump, it simply rotates CCW as opposed to the older pumps, which were clockwise rotation.
