Pitman arms/'98 GMC p/u
Old 02-06-02, 01:10 AM
doubleace36
Question Pitman arms/'98 GMC p/u
Need to replace Pitman arm and ball joints, What's the easiest way to go???
Old 02-06-02, 01:16 AM
knuckles
The pitman arm requires a puller. You can rent or buy one from your local autoparts store.
The upper balljoints are riveted in place. You'll need to drill or cut the rivets to remove them. The replacement joints will come with bolts to replace the rivets you remove.
The lower balljoints are pressed in place. You'll need to buy or rent a balljoint press to replace them safely.
If you plan to tackle this job yourself, get a Haynes or Helm manual. You'll need it! This job is not especially difficult, but you need to know what you're doing to avoid hurting your truck or yourself.
Old 02-06-02, 10:58 AM
redneck
Just out of curiosity how many miles on your '98 GMC?
Old 02-06-02, 03:55 PM
doubleace36
Thanks, I think I will try that, but if the top ball joint has no rivets just a nut does that mean it's been done already?
Old 02-06-02, 03:56 PM
doubleace36
redneck answer
there is 189000 kms on my GMC
