88 Olds Cutless ciera, running out of gas
Old 02-09-02, 07:27 PM
Guest
The problem started out as sporatic stalling when coming to a stop or making a slow turn while driving at moderate speed.
I changed the fuel filter near the gas tank. It was quite clogged.
The problem seemed to get worse. Car would stall and not restart unless I turned ignition completely off and then on again.
I checked OBD for a dashboard light code. code 44, O2 sensor showed. Changed it , problem still there. The fuel pump was changed 2 years ago. pump totally failed. Could the problem be the throttle position sensor?? any suggestions??
thanks
Skip
Old 02-09-02, 07:36 PM
Joe_F
What does a fuel pressure check with gauge reveal?
That's the next step.
Old 02-10-02, 12:35 PM
trendar
Is there any difference when the tank is full vs. near empty?
May be a problem with the fuel pickup in the tank-
