1988 Camaro, VIN "E" TBI
maitai11's Avatar
02-10-02, 02:07 AM   #1
Hey Joe
I've been getting some "pinging" - not a real sharp loud ping, but kind of a garbled "marbles rolling around" sound while going up hill and accelerating. Any ideas?
Maitai
danc37166's Avatar
02-10-02, 09:41 AM   #2
danc37166
WHAT OCTANE OF FUEL ARE YOU USING? COULD BE PREIGNITION OR SPARK KNOCK. POSSIBILITY OF IGNITION TIMING TOO HIGH, CARBON BUILD UP ON PISTONS, LEAN FUEL MIXTURE, OR EGR SYSTEM NOT WORKING PROPERLY.
mooser1's Avatar
02-10-02, 10:48 AM   #3
mooser1
most common cause of spark knock in later model computer controlled engines is the "knock" sensor, located in front of and slightly above the starter on your car.....if the wires are in place to it, sometimes they get hit by flying road debris, then replacing the sensor itself will probably fix the problem......the data from this sensor tells your computer to retard timing when accelerating or under heavy load, much the same as the "vacuum advance" units did on pre-computer cars......I'm sure Joe will agree, this is a logical place to start looking......
Joe_F's Avatar
02-10-02, 07:21 PM   #4
Joe_F
It sure is. Good job Mooser
I also agree with Dan.
maitai11's Avatar
02-20-02, 02:54 PM   #5
Fuel Pressure..............
Hey Joe/Everyone
Would you happen to know what the fuel pressure is on this model leading into the TBI unit? I would like to install a clear fuel filter, and cannot do so if the psi is greater than 10. I have a model 220 TBI unit on this 88 Camaro, 305.
Thanks alot!!
Maitai
mooser1's Avatar
02-20-02, 03:16 PM   #6
mooser1
fuel pressure should be between 9 and 13 lbs factory specs...a little much for this filter I suspect...
Joe_F's Avatar
02-20-02, 09:43 PM   #7
Joe_F
Check the links in my signature file for service manual information.
No need for another filter. Change the factory one regularly..no problems.
Inline filters that are clear aftermarket serve zero benefit and look major league hokey on a modern car
maitai11's Avatar
03-04-02, 07:40 PM   #8
Stereo speakers
Hey Everyone,
I'm looking to put new speakers in. Besides the 4x6 ones in the front on the dash, what other options to I have? Also, what is a good brand for the price?
Maitai
Joe_F's Avatar
03-05-02, 03:22 AM   #9
Joe_F
Check out www.crutchfield.com.
They usually have good stuff.
