Son`s Truck
Old 02-10-02, 05:37 PM
Son`s Truck
My son has a 95 S-10 with V6. Today he washed the engine, it ran rough for a while, stalled, and now will not start. Any good start point tips?
Old 02-10-02, 05:43 PM
danc37166
MOST LIKELY YOUR DISTRIBUTOR CAP HAS MOISTURE IN IT. YOU MIGHT REMOVE IT AND DRY IT OUT WITH A HAIR DRYER OR SIMPLY REPLACE THE CAP AND ROTOR. HOPE THIS HELPS.
Old 02-10-02, 05:45 PM
tstokka
did he use a pressure washer? could have made a wire come off somewhere.
Old 02-10-02, 05:50 PM
Son`s truck
Thanks, I`ll try it
Old 02-10-02, 05:51 PM
mooser1
I agree, computer controlled engine management systems and moisture do not get along....if drying the cap out doesn't help he'll have to start unplugging some of the electrical connectors on the engine and firewall and make sure these connections are dry.....odds are if he lets it sit overnight it will run again in the morning, but he should refrain from actually "washing" the engine, this could become costly, especially if it shorts out the computer.....good luck.....
Old 02-10-02, 07:00 PM
Joe_F
Yup, something got wet.
Could also have bad ignition wires which are old and are taking on the moisture.
