mazda 626 engine light
Old 02-11-02, 09:32 AM
donald l nauls
Question mazda 626 engine light
the check engine light keeps coming back on,i changed plugs
fuel filter .the light went out for a couple of days but came back on
i also had the car put on engine analyzer the repairman said
he wold have to go through several things to diagnose the problem.do you have any ideas
Old 02-11-02, 09:35 AM
Joe_F
It helps to know the year and engine size of the subject vehicle.....
Could be a number of things. You can probably check the codes yourself. Follow the directions in the link in my signature file (the one for www.batauto.com)
Need more information to help.
Old 02-11-02, 09:40 AM
donald l nauls
mazda 626
its 1998 mazda four cylinder with 40.000 miles
Old 02-11-02, 09:42 AM
Joe_F
1998 is OBDII and requires a code reader or scanner to pull codes.
Hit your local Autozone store or parts store with a tool rental program. They will rent you a scanner.
Hook it up and determine what the codes are. Tell us what you find.
Still don't know the engine size as I requested in the first reply.
Must furnish all details for us to help. What is the actual performance issue/trouble with the car?
