95 beretta quit running
Old 02-12-02, 07:19 AM
jz brake
Question 95 beretta quit running
Hi ! I'm back JZ Brake. I have a 1995 Beretta 3100 Vin# M, auto transmission, and air cond. that was running sluggish. I've checked the fuel filter, it was OK. I checked for water in the fuel, it was OK, fuel pressure was 38 PSI, secondary ignition seems OK, has good spark and ect. I scanned the computer, and came up with code 33, A/F ratio was reading 10.4. I replaced the map sensor, now I have 14.7 A/F ratio. The car is running fine, but I'm stumped, the car will quit running as if you turned the key off, you might drive 5 miles or 25 miles before this happens. I rescanned the computer there is no code and everything looks good. Any ideas will be greatly appreciated.
You can contact me at [email protected]
Old 02-12-02, 07:48 AM
Joe_F
When it quits will it start right back up again?
Does www.alldata.com show any bulletins on this problem?
Old 02-12-02, 10:43 AM
mooser1
I agree, check the TSB's for this vehicle.....lots of later model GM rigs have trouble with faulty ignition switches that have to be replaced.....
Old 02-14-02, 06:06 AM
jz brake
joe_F, 95 BERETTA QUIT RUNNING
YES THE CAR START RIGHT BACK UP
Old 02-15-02, 08:25 PM
jz brake
Thumbs up 95 beretta is fix
i invested in a snapon 2500 scanner and a 2400 mutimeter,recheck the system. it turned out that the first
map sensor bought from O'reily's was bad, the reason, the sensor held vacuum but would'nt decrease or increase the voltage when the vacuum change.
