1993 mercury grand marquis
Old 02-12-02, 10:03 AM
Guest
How do you get to the tail light assembly in order to change a bulb?? Do you go in thru the trunk?? Is there a panel that comes off or what??
Old 02-12-02, 10:04 AM
Joe_F
Fold back the trunk liner and there should be bolts holding it through the body.
They are usually metric. Remove them and the light should come out. Now you can change the bulb.
Reverse to install and should be done now.
Old 02-12-02, 07:09 PM
cheese's Avatar
Received 46 Votes on 41 Posts
My mom's car is a '95 crown victoria, don't know if they're the same, but on hers, you fold back the liner like Joe said, and there are 5 or 6 black plastic wing nuts that you remove. Then wiggle and pull on the lens to get it out. GL!
